SimpleSpaces Posted 5 hours ago Share Posted 5 hours ago Good morning! I am stuck on what seems to be simple fix. I am drawing a simple 14 x 20 cabin with a shed roof. I can't get the framing to stop running through the windows on the high side. The back wall is 7', hence why the framing is running all the way around, but I don't know how to fix it. Any help would be appreciated! I'm using Home Designer Pro 2021. Link to comment Share on other sites More sharing options...
SteveCanbury Posted 4 hours ago Share Posted 4 hours ago If you can upload the .plan file it helps others diagnose your problem Link to comment Share on other sites More sharing options...
SimpleSpaces Posted 2 hours ago Author Share Posted 2 hours ago Accessory Buildings.plan Link to comment Share on other sites More sharing options...
SteveCanbury Posted 2 hours ago Share Posted 2 hours ago I changed a couple parameters, sorry I'm not sure which one fixed it. Maybe you can review the file and figure out what i changed. My Bad ... It's been a long day ... 865765995_AccessoryBuildings.plan Link to comment Share on other sites More sharing options...
SimpleSpaces Posted 1 hour ago Author Share Posted 1 hour ago Thanks for trying. I can't open your file without upgrading my plan which isn't in the budget right now. If can figure out how you fixed it, please let me know. Link to comment Share on other sites More sharing options...
ChiefTylerL Posted 10 minutes ago Share Posted 10 minutes ago Hello @SimpleSpaces, It looks like that wall isn't set to follow its default top height, which is causing the framing to generate incorrectly. To fix this: 1. Select the problem wall and open its specification 2. Go to the Structure panel and check the box for Default Wall Top Height 3. Rebuild your wall framing I hope this helps! Link to comment Share on other sites More sharing options...
