PoiPounder Posted March 2 Share Posted March 2 (edited) I don't know if I am just too naive or if the file was set up incorrectly from the surveyor, but I can't figure out how to import the boundary and elevation data into my new project properly. Attaching the file below. I have followed other posts on the import process, but keep having issues. Can anyone tell me if it's possible with this file? Everything seems to be under the label "0" for what I need. The perimeter boundary as well as the elevation data. Unsure how to correct this and import the proper way. I noticed that the jagged elevation lines are in one big block, unsure how to separate those out? I would really appreciate your help with this daunting endeavor. Using Chief 10 23-84 subd 7-2-24.dwg Edited March 3 by PoiPounder Link to comment Share on other sites More sharing options...
SteveCanbury Posted March 4 Share Posted March 4 Worked fine for me. BUT, I think what is going on, there are 2 drawings that are separated, I'm assuming they should be superimposed. If you scroll WAAAAY out you'll notice 1 part of the image (appears to be a neigborhood/ cul de sac) with no information on the top right corner. THEN to the bottom left is all your Compass and Elevation Data. As far as how to proceed from there, That is beyond my current level of Chief knowledge. Hope this helped you get a little further. New Plan > File > Import > Import Drawing In the Import Drawing Assistant I used these settings shown in screenshots ... Link to comment Share on other sites More sharing options...
SteveCanbury Posted March 4 Share Posted March 4 (edited) Problem Solved I removed the black overlay and moved the Information Layer Chief User DWG.plan Edited March 4 by SteveCanbury Link to comment Share on other sites More sharing options...
PoiPounder Posted March 5 Author Share Posted March 5 (edited) I can import the file, but actually converting that into elevation data to show the gentle hill is what I can't figure out how to do? I don't necessarily need all the information. Just the boundaries and the ability to import the terrain data that actually will translate on the program. Instead of seeing the lines, actually have it affect how the terrain and elevation look. Any ideas? Unfortunately I have an older version of Chief and can't open the file you created. I appreciate you doing so though. Thanks for going above and beyond. The other thing I don't get is that when you click on the elevation lines in the plan its one giant BLOCK. not separate information. Edited March 5 by PoiPounder missed something Link to comment Share on other sites More sharing options...
BenPalmer Posted March 5 Share Posted March 5 https://www.chiefarchitect.com/support/article/KB-00719/importing-terrain-elevation-data-from-a-dwg-or-dxf-file.html https://www.chiefarchitect.com/videos/watch/1056/import-a-surveyor-dwg-file-for-a-site-plan-or-terrain-perimeter.html 1 Link to comment Share on other sites More sharing options...
PoiPounder Posted March 10 Author Share Posted March 10 I am seriously banging my head against the wall here. Watched both videos and followed all steps and it's just not working. From what I can tell there are only really 3 contour elevation data points, which is very odd. The other numbers seem like they are just labels, which makes no sense as there is a berm at the bottom of the lot on the wider side of the dwg file. The perimeter isn't closed and i have to try and reconnect it to convert to my terrain perimeter. It's a real pain the as* and doesn't work like the videos say it should. Sometimes i have to retrace the whole polyline just to be able to close it and create a terrain perimeter. The elevation data points just don't work. I swear I am doing something wrong. The company that did the survey told me the elevation data was on the POINTS label, but it really doesn't do anything when i import it that way. Any ideas? Does this create properly for you when you import it? Am i just daft? Link to comment Share on other sites More sharing options...
PoiPounder Posted Tuesday at 10:05 PM Author Share Posted Tuesday at 10:05 PM I select Terrain>Elevation Data>Elevation Line and trave the ones that have actual elevation data (52, 50, 48) and I get this whack elevation map afterwards. Do I need to trace every single one of the contour elevation lines? Any advice would be greatly appreciated. Link to comment Share on other sites More sharing options...
JiAngelo Posted Wednesday at 10:39 AM Share Posted Wednesday at 10:39 AM (edited) The surveyor needs to unblock everything on Layer 0. Your points() layer is importing as a block on Layer 0. Select one and you can only hide it by turning off Layer 0. Turning off the points() Layer does nothing until you unblock an object on Layer 0. Chief can't read points data within a blocked object. Contact your surveyor and have him send you the unblocked model. He exported his plan view. Also, the unit of import is Feet. Edited Wednesday at 10:41 AM by JiAngelo Additional info Link to comment Share on other sites More sharing options...
PoiPounder Posted Saturday at 08:05 PM Author Share Posted Saturday at 08:05 PM (edited) I called him and asked him to unblock everything and he sent me this file. Now it seems not to work more so than before... I don't know what to do at this point. Does this seem like it works for you when you open it? I don't even see the perimeter lines anymore... john updated23-84 draft subd (1).dwg Edited Saturday at 08:05 PM by PoiPounder Link to comment Share on other sites More sharing options...
JiAngelo Posted yesterday at 12:26 AM Share Posted yesterday at 12:26 AM Actually, import with Contours as elevation data and you will find the data is there on Contours. The one I selected says 49' If you zoom in you will see your points(4-13-24) fall between the correct contours. Unfortunately, your going to need to call him back and tell him "unblock everything" includes everything, not just some things. Everything on Points(4-13-24) is still in blocks on Layer 0. And Chief doesn't assign elevation data to a block. Red circle is his block of points(4-13-24) data, still blocked up on Layer 0.. Green circle is after I unblocked one group. It contains 4 objects. Chief needs them unblocked to read the data. Technically the elevation "X" point & Point.ELEVATION data (49.505) should be on its own layer. Point.NUMBER (129) and Point.NAME (GD) should be on separate layers. At least that's how my equipment exports them and Chief loves it. And if he doesn't move Point.NUMBER to another layer, you may find an elevation 129' and 49.505' right beside one another. If you tell Chief Points(4-13-24) is elevation data, when you import now the "X" disappears, but no values are set because the data is in a block In case he still doesn't get it, show him this. This is a block of points(4-13-24) data. Notice it is also on Layer 0 (as a Cad block). You can only turn it off by selecting Layer 0. Selecting the points() does nothing. And show him this. This is after I unblocked the group. Notice they all now exist individually on only the points(4-13-24) layer. Pro Tip - the Boundary is on BDRY2, and true to form, it isn't closed. In fact it's nowhere close. The BLACK and RED lines don't share a common point, so they can't join with one another. The GREEN line has no "Polylines, Label" Layer so it can't join with either Black or Red, which do have a "Polylines, Label" Layer. And I don't know if the YELLOW line means this is two lots, but it has no "Polylines, Label" Layer either and neither BLACK or RED have breaks in their lines where YELLOW meets them.. Chief requires all to be the same to connect automatically. This just means you are going to have to draw that terrain perimeter yourself. Not the end of the world, but just maddening when surveying is all about precision. Hope this helps. 1 Link to comment Share on other sites More sharing options...
