CA_Russell Posted February 12 Share Posted February 12 All, I can build a standard residential plan set to default height: 109 1/8". Then I can adjust the room heights via ROOM OBJECTS. What I cannot seem to understand is if I have a common room height, say 10'... .. then I need to adjust outside plate heights for added interest / design elements to 14 ft. How is this effectively achieved without breaking the AUTO tools? Ryan Russell Link to comment Share on other sites More sharing options...
Rookie65 Posted February 12 Share Posted February 12 Please post questions under the "Q&A" section. You'll get more activity there. This section is for people to post the tips and techniques they've found to help others. Link to comment Share on other sites More sharing options...
SNestor Posted February 13 Share Posted February 13 On 2/12/2026 at 12:48 PM, CA_Russell said: All, I can build a standard residential plan set to default height: 109 1/8". Then I can adjust the room heights via ROOM OBJECTS. What I cannot seem to understand is if I have a common room height, say 10'... .. then I need to adjust outside plate heights for added interest / design elements to 14 ft. How is this effectively achieved without breaking the AUTO tools? Ryan Russell "Rooms" dictate the height of walls. Try not to drag a wall up/down...walls you drag will never change until you "reset" them to "default". Set your default room height in "defaults". Only make changes to individual rooms using the room dialogue as needed. Once you use the room dialogue to make a change...changes made to your defaults will no longer effect those rooms. 1 Link to comment Share on other sites More sharing options...
