kwhitt Posted January 28 Share Posted January 28 I just recently upgraded to X17 and am looking for a way to back up my project as it was in X16. I don't want the new project file as I can't access individual image maps. I often tweak my image maps in Photoshop and will need direct access to the map. Is there a way to "Back up Entire Project" like it was in X16? Thanks, Kevin Link to comment Share on other sites More sharing options...
kwhitt Posted January 28 Author Share Posted January 28 I should have mentioned that I have Project Management turned off. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 28 Share Posted January 28 (edited) The .caproj file that gets exported when using the Export Plan as Project tool is nothing more than a special zipped folder. You can manually change the extension of the resulting file to .zip instead of .caproj You can then unzip and access/edit all the internal files. Edited January 28 by Alaskan_Son 1 Link to comment Share on other sites More sharing options...
kwhitt Posted January 28 Author Share Posted January 28 18 minutes ago, Alaskan_Son said: The .caproj file that gets exported when using the Export Plan as Project tool is nothing more than a special zipped folder. You can manually change the extension of the resulting file to .zip instead of .caproj You can then unzip and access/edit all the internal files. Thanks. I was hoping that was the case. Link to comment Share on other sites More sharing options...
