AnkhRea Posted 9 hours ago Share Posted 9 hours ago Hello, I am new in this software. I made a leveled terrain (2% slope). I have separated parts on my terrain. For the large part, the house, everything is ok, the floor is on the terrain. But when drawing the walls of the second part of the property which is on the lower terrain, my walls are floating in the sky, approximately 20cm because the 0 level is on the main house. How can I create a new 0 level for the second part of the estate? Thank you Link to comment Share on other sites More sharing options...
PitMan71 Posted 9 hours ago Share Posted 9 hours ago Is the second part connected? part of the same floor, just lower? Link to comment Share on other sites More sharing options...
PitMan71 Posted 9 hours ago Share Posted 9 hours ago This might be helpful. Link to comment Share on other sites More sharing options...
AnkhRea Posted 2 hours ago Author Share Posted 2 hours ago 6 hours ago, PitMan71 said: Is the second part connected? part of the same floor, just lower? No. It is really another small garden house at the end of the terrain Link to comment Share on other sites More sharing options...
Mark3D Posted 2 hours ago Share Posted 2 hours ago 6 hours ago, AnkhRea said: Hello, I am new in this software. I made a leveled terrain (2% slope). I have separated parts on my terrain. For the large part, the house, everything is ok, the floor is on the terrain. But when drawing the walls of the second part of the property which is on the lower terrain, my walls are floating in the sky, approximately 20cm because the 0 level is on the main house. How can I create a new 0 level for the second part of the estate? Thank you I think you just need to put -20cm in the room floor height of the small gardern house If that does not make sence upload your plan Link to comment Share on other sites More sharing options...
