2 Seperate Wall Tags for Pony Wall
EmmaCox
Is there a way to show 2 seperate wall tags for a pony wall?
For example, on the wall schedule I am wanting to show exterior wall W1 framed wall with siding and W2 with stone, as the entire home does not have pony wall / stone skirting. So in the areas with the pony wall I could just have 2 tags rather than creating W3 with both siding and stone.
Another example is I have a portion of the foundation wall that is a daylight basement, so there would be say W4 foundation wall and W2 framed wall with stone (same as above).
You would need a pretty custom macro that to examine upper and lower wall layers and text label or you would need a custom macro and 2 schedules. Where 1 schedule ignores schedule- callouts of the other as to avoid duplications
This video is paywalled but you are doing something similar in that you want a schedule-callout from each schedule but you dont want the callout to populate numbers from both
Alternatively, I am curious if simply using a callout with a detail would work better. In terms of it being a plan-set to build from, the builder will need to see a detail for your pony wall connections and relative heights anyways, so you could just drop a callout on each wall:
image.thumb.png.df9b6c7f967cc63fe072579530be9772.pngimage.thumb.png.95c273ed494829c551632571e2165e74.png
