tinyhouseguy Posted January 9 Share Posted January 9 I'm trying to connect a deck with no railings on the front of a simple square cabin, no floor shows up, but if I create a deck with rails it works fine, if i create a deck without rails off to the side it works fine too, anyone want to throw me some ideas on what I might be doing wrong or overlooking, thanks, Tim Link to comment Share on other sites More sharing options...
DBCooper Posted January 9 Share Posted January 9 Are you using the "straight deck edge" tool to draw your deck? I think all this does is create a deck rail and mark it as "invisible". So you could probably just take your deck with rails and make the rails invisible. Link to comment Share on other sites More sharing options...
tinyhouseguy Posted January 9 Author Share Posted January 9 (edited) yes , the straight edge, and what you describe as marked invisible is what I'm getting, but it works perfect off to the side not connected to the building as a deck without railings. Edited January 9 by tinyhouseguy Link to comment Share on other sites More sharing options...
DBCooper Posted January 9 Share Posted January 9 The only other thing I can think of would be a room definition problem. If you still can't figure it out, then you might want to post your plan. Link to comment Share on other sites More sharing options...
tinyhouseguy Posted January 9 Author Share Posted January 9 I'll try that, thanks for your ideas Link to comment Share on other sites More sharing options...
