jhoney Posted 8 hours ago Share Posted 8 hours ago Good morning all, I am a Chief X16 user. Having footing problems. I have a front porch that I want to slightly extend out past the face of the house because the porch column bases will extend beyond the beam. The problem I have is that when I bump the footing line out to accommodate for that, it pulls the footing too far. I've tried the Edit Wall Layer Intersections, but I can't get the footing to adjust to where I want it to go. Does anyone have any suggestions? Attaching pics of my issue. Link to comment Share on other sites More sharing options...
PitMan71 Posted 6 hours ago Share Posted 6 hours ago Hey. I have had this issue as well. I have had to do work arounds for it AND I have put in a ticket with chief to improve the overall wall cleanups giving the user more control since more often that not there are situations like this that require finesse and don't fall in line with the wall directives, while they work to your advantage most of the time, work against you sometimes. Post your plan and maybe someone in the forum can help find a work around or solution. Link to comment Share on other sites More sharing options...
jhoney Posted 3 hours ago Author Share Posted 3 hours ago Thanks for the info. Very frustrating sometime that things that seem so easy are made so cumbersome! Link to comment Share on other sites More sharing options...
Renerabbitt Posted 37 minutes ago Share Posted 37 minutes ago 2 hours ago, jhoney said: Thanks for the info. Very frustrating sometime that things that seem so easy are made so cumbersome! Share your plan file please Link to comment Share on other sites More sharing options...
