rcmcdougle Posted 7 hours ago Share Posted 7 hours ago Opening a different plan in the same session and the dimensions work correctly. What settings should I look at? On further study, everything BUT the walls will take a dimension. I checked and the walls do not have the >No locate< checked. Temp dimensions do work on all walls. Link to comment Share on other sites More sharing options...
DBCooper Posted 6 hours ago Share Posted 6 hours ago Check your active dimension defaults. Make sure your manual dimensions are set to locate the walls and the correct sides of the walls. Link to comment Share on other sites More sharing options...
rcmcdougle Posted 5 hours ago Author Share Posted 5 hours ago 43 minutes ago, DBCooper said: Check your active dimension defaults. Make sure your manual dimensions are set to locate the walls and the correct sides of the walls. That fixed it. Not sure how this got changed as it was working properly in that plan yesterday. Also interesting - with that plan loaded and dimensions failing, I load a different plan in the came Chief session and the dimensions work as expected. I did not realize these default settings were held by the plan as this behavior would indicate. Thanks for your help. Link to comment Share on other sites More sharing options...
