Importing Revit Models
JDT63Drafting
Just to clarify, you can't import a revit model as a smart Chief model that you could then modify.  You can import a 2D drawing using a DWG/DXF format that you could then trace over or you could import a 3D model using a format that revit can export that you could view but that's about it.
Hi @JDT63Drafting, You can however convert certain parts of a 2D DWG/DXF file that you import into CA into walls doors and windows in certain instances. By use of layer mapping when importing the file into CA.
Please read this support article below on how to do so. There are also training videos on how to go about this too.
https://www.chiefarchitect.com/support/article/KB-00170/using-cad-to-walls-from-an-imported-dwg-dxf.html
Edited by mthd97
