Brick Pier Foundation - Tips
PitMan71
Go to solution Solved by robdyck,
I have a project coming up that the foundation is brick piers as shown in the attached images. What is the best way to draw these the way they are shown here? I have looked at the foundation tool with piers but it centers them under the edge of the wall and it doesn't appear they can be moved. Anyway, I will probably be doing a few like this so I want to get it figured out.
Thank in advance for tips on this.
290954454_Screenshot2025-10-08at5_11_29PM.thumb.png.b51f04d2788f412dc5263c6a5e6a2632.png219230908_Screenshot2025-10-08at5_11_56PM.thumb.png.da01e2b1d6b12996f5671be87633cfc6.png
Edited by PitMan71
  • Solution
Posted (edited)
The actual wall type doesn't really matter when the foundation height is 0", but a 16" wide foundation wall gets the piers aligned correctly.
I 'painted' the piers instead of changing the default material for the foundation/slab.
The pier spacing I used is simply an example. Everything here is automatic.
Edited by robdyck
