PitMan71 Posted Wednesday at 10:17 PM Share Posted Wednesday at 10:17 PM (edited) I have a project coming up that the foundation is brick piers as shown in the attached images. What is the best way to draw these the way they are shown here? I have looked at the foundation tool with piers but it centers them under the edge of the wall and it doesn't appear they can be moved. Anyway, I will probably be doing a few like this so I want to get it figured out. Thank in advance for tips on this. Edited Wednesday at 10:17 PM by PitMan71 Link to comment Share on other sites More sharing options...
Solution robdyck Posted Wednesday at 10:34 PM Solution Share Posted Wednesday at 10:34 PM (edited) The actual wall type doesn't really matter when the foundation height is 0", but a 16" wide foundation wall gets the piers aligned correctly. I 'painted' the piers instead of changing the default material for the foundation/slab. The pier spacing I used is simply an example. Everything here is automatic. Edited Wednesday at 10:35 PM by robdyck 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted 21 hours ago Author Share Posted 21 hours ago Thanks.... Im gonna go try this now. 1 Link to comment Share on other sites More sharing options...
