QuickDraw59 Posted Monday at 06:40 PM Share Posted Monday at 06:40 PM (edited) Still a newbie. Running Premier X17 on an (apparently) robust PC processing and storage. see pix and plan for example I have standard 4.5" thick walls (1/2"-3.5"-1/2") meeting thicker walls ( 1/2" - multiple 2x4s - 1/2") and I have exposed interior material showing. Also, for uncased archways, I leave a jamb but change to drywall texture, otherwise the internal material "ghosts" through. But I want the baseboard to wrap around. Suggestions, oh wise ones? Edited Monday at 06:47 PM by QuickDraw59 adding version/system info Link to comment Share on other sites More sharing options...
PitMan71 Posted Monday at 06:59 PM Share Posted Monday at 06:59 PM A couple things. When you make a thicker wall I suggest just doing a stud on both sides with an air space gap between to make the thickness. On the Sheetrock openings remove the jamb in the opening and it should let the base turn the corners. I know this doesn't look "right" in plan view but in 3d it will look nice..... Chief can do most anything you just gotta learn what its nuances are and work around and within them, if that makes sense. Give my suggestions a go and let me know how it works out. I hope this helps. Link to comment Share on other sites More sharing options...
QuickDraw59 Posted Monday at 07:26 PM Author Share Posted Monday at 07:26 PM Putting the air gap in the wall made the uncased openings stop ghosting the interior material; they are solid drywall now with the baseboard continuing. Awesome, thank you! I didn't cure the junctions of dissimilar-thickness walls, though. Will have to keep pocking at it. Thank you! Link to comment Share on other sites More sharing options...
CharlesVolz Posted Monday at 08:08 PM Share Posted Monday at 08:08 PM 1 hour ago, QuickDraw59 said: and I have exposed interior material showing. You may have something with a thickness as an interior wall layer, other than just the 1/2" drywall. Otherwise, align your 2 walls properly. Or, of course, you could post the plan... Also, I see four areas where drywall is missing, but I am not sure which ones you are thinking of. Link to comment Share on other sites More sharing options...
QuickDraw59 Posted Monday at 08:48 PM Author Share Posted Monday at 08:48 PM ChArch plan file is too big to attach? 47,346 KB getting error message that attachment exceeds 14MB file size limit? photo: red arrows missing drywall where unequal thick walls connect. These walls line-up drywall-to-drywall in PLAN blue arrows drywall OK but corners where two unequal thick walls connect (appears to be same conditions with different outcomes) Link to comment Share on other sites More sharing options...
CharlesVolz Posted Monday at 09:46 PM Share Posted Monday at 09:46 PM Post a link to the plan. Upload the plan to Google Drive, Dropbox, etc.... Link to comment Share on other sites More sharing options...
