rikdekker Posted September 11, 2025 Share Posted September 11, 2025 Does anyone know a trick to convert text to a solid? I'm trying to make cut out letters for a sign Link to comment Share on other sites More sharing options...
JKEdmo Posted September 11, 2025 Share Posted September 11, 2025 6 minutes ago, rikdekker said: Does anyone know a trick to convert text to a solid? I'm trying to make cut out letters for a sign This might help: https://www.chiefarchitect.com/support/article/KB-00709/creating-a-sign-with-3d-lettering.html Also, if you have access to Autocad, it's possible to explode text into a polyline using Express Tools which you can then extrude if I recall correctly. You could import this into Chief I imagine. 1 Link to comment Share on other sites More sharing options...
rikdekker Posted September 11, 2025 Author Share Posted September 11, 2025 Thanks Jim for an amazingly quick response. I will go through that link and check it out. Much appreciated. Link to comment Share on other sites More sharing options...
rikdekker Posted September 11, 2025 Author Share Posted September 11, 2025 That's awesome. Great tool to have in my tool chest. Unfortunately my client was looking for the Rockwell font. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 11, 2025 Share Posted September 11, 2025 9 minutes ago, rikdekker said: That's awesome. Great tool to have in my tool chest. Unfortunately my client was looking for the Rockwell font. 1 Link to comment Share on other sites More sharing options...
rikdekker Posted September 11, 2025 Author Share Posted September 11, 2025 Thank you so much! I feel like I just sat in on a wizards class! Amazing Link to comment Share on other sites More sharing options...
rikdekker Posted September 12, 2025 Author Share Posted September 12, 2025 @Renerabbittworks except when I select it the only available option to convert to is "molding polyline". Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 12, 2025 Share Posted September 12, 2025 5 minutes ago, rikdekker said: @Renerabbittworks except when I select it the only available option to convert to is "molding polyline". You're missing a step then. Explode it if it came in as a cad block ...else make sure it's a closed polyline. Can't convert a open polyline to a solid Link to comment Share on other sites More sharing options...
rikdekker Posted September 12, 2025 Author Share Posted September 12, 2025 When I opened object it said "area not closed". Checked every point and was unable to find where it was open so I added an arrow and was able to find the start and end points. Works now. I really appreciate your input. Thanks so much. Link to comment Share on other sites More sharing options...
