PitMan71 Posted September 8, 2025 Share Posted September 8, 2025 Is there a tip to snap to intersections and such in a CAD block? I find myself having to explode them in order to position correctly and then re-block. Thanks Link to comment Share on other sites More sharing options...
DBCooper Posted September 8, 2025 Share Posted September 8, 2025 Have you tried editing the cad block and setting the insertion point where you want it? Link to comment Share on other sites More sharing options...
PitMan71 Posted September 8, 2025 Author Share Posted September 8, 2025 I haven't, BUT I will see if that helps. I make blocks of most things I create and add to library for use in other drawings.... Some things will not stay blocked, but some things it would nice if I can leave them that way for convenience. It can be challenging when trying to snap to an intersect or an end in one of those blocks. I was hoping there was some tip or whatever to be able to do that aside from some work around, if that makes sense. Link to comment Share on other sites More sharing options...
