rcapone Posted Sunday at 11:32 PM Share Posted Sunday at 11:32 PM Are there lights for pools? I made a pool, for the walls I used the slab function and modified. I want to get lights on the sides which I figure would be like a recess light but on a wall and not a ceiling. Is there any trick to doing this? This is only needed for 3D purposes. I can just put the light symbol on the electrical plan. Link to comment Share on other sites More sharing options...
mtldesigns Posted yesterday at 12:19 AM Share Posted yesterday at 12:19 AM (edited) 47 minutes ago, rcapone said: Are there lights for pools I made my own, by copying a 6" recess light to my user catalog then renamed it so I knew what kind of light it was. "Open Object" that part in your user catalog. Go to the 3D tab, and rotate this fixture, I believe on the Y axis +90 degrees Then go to the Options and make this floor mounted. (I could never get this to work as wall mounted, even though that is my preferred method) Lastly, go to the 2D Symbol tab, and at the bottom of that page is "Generate Block". This will put the light in the vertical. Place the light on your pool wall, adjust the height A/R. Recording 2025-09-07 201845.mp4 Edited yesterday at 12:20 AM by mtldesigns 1 Link to comment Share on other sites More sharing options...
rcapone Posted 22 hours ago Author Share Posted 22 hours ago Thanks, I have CA 13 so unfortunately I don't have the options you do. But I did an elevation and rotated 90 degrees and it worked. Didn't think about that initially but once I saw what you did I gave it a try. Thanks a mil. Now I just need to understand the light properties lol. Link to comment Share on other sites More sharing options...
rcapone Posted 22 hours ago Author Share Posted 22 hours ago This is how it came out. Link to comment Share on other sites More sharing options...
mtldesigns Posted 22 hours ago Share Posted 22 hours ago 32 minutes ago, rcapone said: This is how it came out. COOL.... Link to comment Share on other sites More sharing options...
Rookie65 Posted 22 hours ago Share Posted 22 hours ago I suppose you could even use horizontal cylinders and make the material "light" too Link to comment Share on other sites More sharing options...
