henry7039 Posted Sunday at 01:54 PM Share Posted Sunday at 01:54 PM Hello, I am not builder but own condo in MI and sit on board that is self managed where we hire contractors etc directly for repairs etc. We are replacing siding through complex and there are many instances where hardie board will need to be flashed into existing exterior. Trying to get some guidance as to proper way to flash these transitions. Z flashing has not been used at these spots as no way to get upper part of flashing under existing. Contractor used a u shaped flashing that rests over top of new hardie at the joint but nothing under the existing above to lock out weather. Any help great appreciated Henry Link to comment Share on other sites More sharing options...
para-CAD Posted Sunday at 04:04 PM Share Posted Sunday at 04:04 PM Hey Henry, People on this site will show how to draw this detail......but you might have more interaction over at www.diychatroom.com Link to comment Share on other sites More sharing options...
JKEdmo Posted Sunday at 04:57 PM Share Posted Sunday at 04:57 PM 3 hours ago, henry7039 said: Hello, I am not builder but own condo in MI and sit on board that is self managed where we hire contractors etc directly for repairs etc. We are replacing siding through complex and there are many instances where hardie board will need to be flashed into existing exterior. Trying to get some guidance as to proper way to flash these transitions. Z flashing has not been used at these spots as no way to get upper part of flashing under existing. Contractor used a u shaped flashing that rests over top of new hardie at the joint but nothing under the existing above to lock out weather. Any help great appreciated Henry Henry, U-shaped flashing at the top of siding sounds wrong, but a little hard to tell from the photos. In any case, James Hardie website has details available showing proper installation which should give you direction: Link to comment Share on other sites More sharing options...
henry7039 Posted Sunday at 05:39 PM Author Share Posted Sunday at 05:39 PM Thank you Link to comment Share on other sites More sharing options...
