Chiefnewell Posted September 3, 2025 Share Posted September 3, 2025 1) Wall in outdoor room on one side behind kitchen has disappeared. What do I do to get it back? (Floor Plan 2) I closed up between floors and the existing wall disappeared when I copied beam from one side to the other. Wall is surpose to look like floor plan zipped. 2) How do I follow the roof with exist. fixed glass in attic wall. NEED HELP. JUST PUTTING PLAN BACK AS EXISTING FROM WIND BLOWING ROOF AND RAILING OFF AT A LAKE. 3d rendering issues of wall 00.02.2025.pdf Floor Plan (2).zip Floor Plan.zip Link to comment Share on other sites More sharing options...
DBCooper Posted September 3, 2025 Share Posted September 3, 2025 0 - it's better to post pictures directly on the forum so people don't have to download a pdf to see them. it's always good to make it easier for people to help you if you can. 1 - it looks like somehow you made the wall into a room divider (invisible wall). maybe you accidently drew over it with an invisible wall which replaced it? not really sure but you can "fix" it by turning off the invisible option or redrawing it with the right wall type. your doorways are gone though so you may want to copy the ones from your older plan or just rebuild them. 2 - you can't use match roof if you want to make a doghouse shaped window. This tech article will explain how to do it manually: https://www.chiefarchitect.com/support/article/KB-00036/creating-shaped-windows.html Link to comment Share on other sites More sharing options...
