Cadwork22 Posted August 30 Share Posted August 30 I created a wall framing type and its interfering with doors and windows, is it possible without re framing to frame each opening individually? Thanks in advance for your help. Link to comment Share on other sites More sharing options...
robdyck Posted August 30 Share Posted August 30 Not using an auto frame function. You can frame walls on a per wall basis, but not openings. Some crafty work with copy / paste-in-place of the existing framing combined with a rebuild and deletion operations may work, but by that time it's probably easier to make manual adjustments. 1 Link to comment Share on other sites More sharing options...
