Chiefnewell Posted August 18, 2025 Share Posted August 18, 2025 Monday, Aug 18, 2025 - 01:44 PM PDT How do I have architecture layout floor plans (2-story) Layout Electrical Plan (2-story) It changes the architecture when I send the electrical to the layout page 2. This is a remodeling of just the interior. I copied the architecture floor plan layout to layout sheet 2, but how do I make that electrical? 22127 E. Lake Houston Pkwy.Crosby Remodeling.zip Link to comment Share on other sites More sharing options...
DBCooper Posted August 19, 2025 Share Posted August 19, 2025 Your plan and layout are both empty. Might be because you had them open when you tried to make the zip file. Chances are that the problem is that both of your views are tied to the same saved plan view or the same layer set. You might want to have two separate saved plan views, one for each of the views you are sending to layout. Or, you can mark the layout box to unlink it from the saved plan view and just make sure they are using different layer sets. Chief has some tech articles and videos about using saved plan views that you might want to check out: https://www.chiefarchitect.com/support/article/KB-03185/understanding-saved-plan-views.html https://www.chiefarchitect.com/videos/watch/2421/saved-plan-views.html If nothing works for you, then try posting your layout and plan again. Or contact tech support. Link to comment Share on other sites More sharing options...
