Delete all dimensions button
FREEDOMDESIGN603
So I upgraded to X17 and I find the delete all dimensions button is gone. Is this something I can turn back on? I liked it because when you mull windows together it doesn't re-dimension the windows so I just delete all and auto dimensions.
I know I can select one and click select objects button but that is three more clicks then needed.
It looks like the Delete Dimensions button was removed from the Dimension Tools parent in X17.
It's still available in the menu (CAD > Dimensions > Delete Dimensions), and you can add it to your toolbars using the Customize Toolbars dialog.
