FREEDOMDESIGN603 Posted 17 hours ago Share Posted 17 hours ago So I upgraded to X17 and I find the delete all dimensions button is gone. Is this something I can turn back on? I liked it because when you mull windows together it doesn't re-dimension the windows so I just delete all and auto dimensions. I know I can select one and click select objects button but that is three more clicks then needed. Link to comment Share on other sites More sharing options...
ConnorE Posted 17 hours ago Share Posted 17 hours ago It looks like the Delete Dimensions button was removed from the Dimension Tools parent in X17. It's still available in the menu (CAD > Dimensions > Delete Dimensions), and you can add it to your toolbars using the Customize Toolbars dialog. 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted 13 hours ago Share Posted 13 hours ago Probably a good thing that it was moved. I have clicked it accidentally before. Link to comment Share on other sites More sharing options...
DBCooper Posted 6 hours ago Share Posted 6 hours ago You can also use the "tool search" tool. If you add it to your toolbars, then all you need to do is start typing "delete" and it will show up. It's a quicker way of finding tools then just looking through the menus. Link to comment Share on other sites More sharing options...
