GrizzL Posted August 11 Share Posted August 11 In the same exact session that they were previously working. Been hitting quite a few bugs with 17 but I guess it should be expected. I have tried all 3D tools with this same result. Link to comment Share on other sites More sharing options...
Solution PitMan71 Posted August 11 Solution Share Posted August 11 I would call support. They are very responsive. Link to comment Share on other sites More sharing options...
DBCooper Posted Tuesday at 08:01 PM Share Posted Tuesday at 08:01 PM Sounds like a video card problem but it could be something wrong with just that plan. If it happens with all plans, then it is almost always a video card problem. In any case, Shane is right, you probably want to work with tech support. Link to comment Share on other sites More sharing options...
GrizzL Posted Wednesday at 01:19 AM Author Share Posted Wednesday at 01:19 AM I did. Although my issue is niche I should add here that it was an issue with my roof trusses. The building method calls for the gable trusses to be placed where Chief considers it outside of the wall. I've always accomplished work arounds for this but never been unable to generate 3d views. Support confirmed that it was a bug and passed it on to devs. Link to comment Share on other sites More sharing options...
