TCB_BdnMY Posted August 6, 2025 Share Posted August 6, 2025 Hey there folks, having some issues with my floor truss's and the Truss Direction label isnt reporting the right size. This is probably something really simple, what am i missing here? Link to comment Share on other sites More sharing options...
Solution robdyck Posted August 6, 2025 Solution Share Posted August 6, 2025 7 minutes ago, TCB_BdnMY said: what am i missing here? I'd suggest you examine the settings for the Floor Structure Definition. If it's checked as Trusses, the truss width is greyed out. Check Joists, change the width, then check trusses. 1 Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted August 7, 2025 Author Share Posted August 7, 2025 21 hours ago, robdyck said: I'd suggest you examine the settings for the Floor Structure Definition. If it's checked as Trusses, the truss width is greyed out. Check Joists, change the width, then check trusses. Ah-HA! of course it was something that easy. Seems a little counter intuitive etc as you have to switch to joists, change, then switch back. But it worked, much appreciated, thank you. 1 Link to comment Share on other sites More sharing options...
