Floor Truss Troubles
TCB_BdnMY
Go to solution Solved by robdyck,
  • Solution
7 minutes ago, TCB_BdnMY said:
what am i missing here?
I'd suggest you examine the settings for the Floor Structure Definition. If it's checked as Trusses, the truss width is greyed out. Check Joists, change the width, then check trusses.
Ah-HA! of course it was something that easy.
Seems a little counter intuitive etc as you have to switch to joists, change, then switch back.
But it worked, much appreciated, thank you.
