Hi everyone, is it possible for chief architect to change a staircase (as per pic) into a ramp, or other way to do a ramp like this?
You can't change a staircase into a ramp, but you can create a curved ramp with the same specifications as the staircase that was used.
You could possibly make the stairs look like a ramp by messing around with custom stringer settings or custom railing settings. That would probable take longer though.
You can use a straight ramp and curve it using the Change Line/Arc tool on the edit toolbar.
Open the dbx and have a look at all the settings.
I left the railings so that you can see the slope better.
