JKraft Posted June 30, 2025 Share Posted June 30, 2025 I built a deck with footing/support beams below. I would like to remove the deck surface and see only the footings and beams so I can place/dimension them. How do I turn off the deck surface? Thanks! Link to comment Share on other sites More sharing options...
mtldesigns Posted July 1, 2025 Share Posted July 1, 2025 2 hours ago, JKraft said: How do I turn off the deck surface? Well, if you have it all on the same level, turning off the "Framing, Deck Planking" will show you your structure. Link to comment Share on other sites More sharing options...
