JKraft Posted 12 hours ago Share Posted 12 hours ago I built a deck with footing/support beams below. I would like to remove the deck surface and see only the footings and beams so I can place/dimension them. How do I turn off the deck surface? Thanks! Link to comment Share on other sites More sharing options...
mtldesigns Posted 10 hours ago Share Posted 10 hours ago 2 hours ago, JKraft said: How do I turn off the deck surface? Well, if you have it all on the same level, turning off the "Framing, Deck Planking" will show you your structure. Link to comment Share on other sites More sharing options...
