Connecting Walls
wesdutka
Hi people.
I have an on going problem getting the exterior walls to connect...the exterior wall to the deck is 15' in height while the other one is a attic wall with stucco on the exterior.  The result is seeing the framing on the corner shown in the exterior picture.  I have been compensating by covering it with a 3D solid but wondering if there is an easier way to draw this so it doesn't result in this type of problem.
Any suggestions are welcomed.
Wes
Yes that's correct...you see the exposed framing.  For the life of me I don't know how to solve this issue.  It may have to do with trying to wrap an exterior wall into a attic wall?
I have run into something similar before. On the upper side wall, click on the wall and use the "Edit Wall Layer Intersection" tool. it will give you additional edit grips on the wall to alter the layers. in this case, you would grab the grip closest to the exterior, probably on the siding, and pull the material in the direction of where the finishes are missing. give it a go and let us how it goes.
Shane
