Terrain is too high
MauraInteriors
Hi everyone. This is my first project in Home Designer Pro. I created an entire outdoor deck with steps down to the lower level (will be a grass/concrete walkway). I did the entire deck design before adding terrain. I'm guessing that was a mistake? Now when I add a terrain perimeter it's way too high and cuts off the steps. I watched a few tutorials and tried making an elevation break and setting the terrain to -24" but it does nothing. Anyone know how I can fix this? Thank you.
Putting a "-" before the number raises the terrain. Read closer what the instruction says. It says terrain below floor. Also, home designer has their own forum. This is the chief architect forum. Post questions in the "Q&A" section
This is the Chief Architect forum, and most of us do not have Home Designer Pro.
That being said in CA you can adjust the terrain by opening the terrain specification dialog and then turning off automatic height and then entering a number that is the difference between the subfloor and the terrain.
