uremodel2014 Posted April 2, 2015 Share Posted April 2, 2015 I have no idea what's going on. I must have changes unwittingly changed something. I went in to a plan and reversed a cabinet layout and now the line weights are crazy heavy. and now, if I open any additional layouts, they do the same thing upon closing. Would anyone have a helpful suggestion? Its kind of driving me nuts. I went into the layouts and looked at the weights there. They are all set at 3 which is what I have been printing at and everything has been fine. Thanks, Mike Problem Layout.pdf Link to comment Share on other sites More sharing options...
MPDesign Posted April 2, 2015 Share Posted April 2, 2015 It sounds and looks like your print default line weight has been changed by accident. Open layout, Look at your print page setup. Advanced line weight options, make sure its set to 100 MM Link to comment Share on other sites More sharing options...
uremodel2014 Posted April 2, 2015 Author Share Posted April 2, 2015 I will try that and let you know. As always, thanks for those who are willing to help. Thanks you Michael, Mike Link to comment Share on other sites More sharing options...
uremodel2014 Posted April 3, 2015 Author Share Posted April 3, 2015 I told you I would get back to you. Its been crazy busy! You were right! Somehow my setting went to 300 in. I know I didn't change it, at least not intentionally. Just weird. Cant thank you enough for the generosity. Thanks so much. Mike Ellis Link to comment Share on other sites More sharing options...
