diyDehnel Posted June 6, 2025 Share Posted June 6, 2025 Is there a way to search for topics/videos/etc. only related to Home Design Pro. All to often I will be looking for something and think it is possible to only discover that it is not a feature of Pro like mulled windows, custom doors, etc. I this instance I am trying to find out if the hand railing of a stair can be converted to a shape other than square. The videos I have seen talk about changing the balusters and newels of a fence but I have not found anything on the topic of hand rails specficially. Any pointers for searching would be appreciated. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 6, 2025 Share Posted June 6, 2025 Use the HomeTalk forum instead… https://hometalk.chiefarchitect.com Link to comment Share on other sites More sharing options...
Rookie65 Posted June 6, 2025 Share Posted June 6, 2025 Go the bonus catalogs Handrails No.01 Fittings. There are several handrail styles to pick from And yes, if you are using the Home Designer series, and not Chief Architect Premier, you should be posting on the Hometalk site, not the Chieftalk. Please fill out your signature as well so everyone knows what program and version year you are using. Link to comment Share on other sites More sharing options...
diyDehnel Posted June 6, 2025 Author Share Posted June 6, 2025 Thanks sorry did not even realize I was not in the correct one. Link to comment Share on other sites More sharing options...
chiefjone9 Posted June 17, 2025 Share Posted June 17, 2025 I totally get your frustration—I'm also using Home Designer Pro and often hit the same wall when features are only in Premier. I haven't found a way to reshape stair handrails in Pro either, just balusters and newels like you mentioned. I usually search with “Home Designer Pro only” plus the feature name on both YouTube and this forum. Would love to know if anyone else has a better search method! _Mini Militia App Lock Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 17, 2025 Share Posted June 17, 2025 1 hour ago, chiefjone9 said: I totally get your frustration—I'm also using Home Designer Pro and often hit the same wall when features are only in Premier. I haven't found a way to reshape stair handrails in Pro either, just balusters and newels like you mentioned. I usually search with “Home Designer Pro only” plus the feature name on both YouTube and this forum. Would love to know if anyone else has a better search method! honestly, the best method is to avoid using this forum unless absolutely necessary, and just stick to the Home Designer forum. Link to comment Share on other sites More sharing options...
