MollyNDG Posted May 20, 2025 Share Posted May 20, 2025 Hello everyone, I'm running into a recurring issue with a mirror material. When I export a layout page with a camera view (standard rendering), the mirror has one or more split lines in the reflection and shows a strange reflection, often including inside of walls. I've tried using different mirror materials, but the problem still pops up. It doesn't happen with every mirror or every camera angle, and I haven’t been able to spot a clear pattern. Has anyone else experienced this? Any tips or insights would be really appreciated! Thanks in advance! MIRROR DISTORTION.pdf Link to comment Share on other sites More sharing options...
DBCooper Posted May 21, 2025 Share Posted May 21, 2025 Haven't seen this myself. Might be a video card/driver issue. You might want to post the plan to see if someone else can see the same thing. Also, it usually works better to post pictures directly instead of as a pdf. You can just do a screen capture or use the "export picture" tool. Link to comment Share on other sites More sharing options...
