When I place a new window it has mullions. How do I remove the mullions?
Select the window, 'open item' (Ctrl+E) to get the Window's Specifications, select the 'Lites' panel and adjust the Across and Vertical as desired.  While you are in that panel, press "F1" and the Chief Help will give more information on the dialogue you have open.
F1/Help is really good...you can search topics as needed.
