Tryingtobezen Posted April 9, 2025 Share Posted April 9, 2025 Hello, I have watched many videos and spoken to the technical support team and no one seems to know what is going on. I have a window in a bathroom and every time I try to use this rendering technique it does not show anything coming through this window. It is either dark or white like its super frosted. I have messed with the background. It is bright and sunny outside of the model. My sun is turned on and high in the sky and the window shows correctly when in standard mode or using CPU ray tracing (3D/Ray Tracing) but this technique takes ages. Anyone experience this and figure out what was going on? Thank you in advance!! Alessandro Current_auto_save.zip Link to comment Share on other sites More sharing options...
SusanC Posted April 9, 2025 Share Posted April 9, 2025 Yes, that is very odd that the glass is frosted in PBR. I tried removing your window and replacing it with another window and everything worked just fine. Have you tried removing that window and replacing it with a new window? Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 9, 2025 Share Posted April 9, 2025 1 hour ago, Tryingtobezen said: Thank you in advance!! surprised tech support wouldnt catch this, you have the material class of your window set to translucent not transparent Link to comment Share on other sites More sharing options...
