skirby19 Posted April 1, 2025 Share Posted April 1, 2025 Hi, I need guidance on how I can draw a flared wall. My picture shows the basic lines in red that I want to follow. I didn't find a previous post. Can someone help lead me in the right direction. Thank you,Flared Wall Plan.plan Link to comment Share on other sites More sharing options...
skirby19 Posted April 1, 2025 Author Share Posted April 1, 2025 Flared Wall Plan.plan Sorry. Tried to load the plan but gave me an error. Sorry, an unknown server error occurred when uploading this file. (Error code: -200) Link to comment Share on other sites More sharing options...
DBCooper Posted April 1, 2025 Share Posted April 1, 2025 Did you have the plan open in Chief when you tried to attach it? That can sometimes cause problems. Maybe the plan was too big. You might want to try putting it into a zip file before attaching it. As for your flared walls question, there is no simple way to just make a wall flared at the bottom like that. You might be able to get what you want by adding a molding to the wall that creates the flare. You could also just create the flare using a poly solid. In both cases, you would just set the material to the same as the wall. Link to comment Share on other sites More sharing options...
