RBSdrafter Posted March 24 Share Posted March 24 Does anyone know if their is a way to manually edit webs in the truss detail view. From what I can tell, they do not behave like most poly-line objects(such as adding break points, changing the profile, etc.). Link to comment Share on other sites More sharing options...
BenPalmer Posted March 24 Share Posted March 24 Yes, unlock the "Framing, Roof Trusses" layer and edit away. 1 Link to comment Share on other sites More sharing options...
JiAngelo Posted March 25 Share Posted March 25 Use the merge and join tools in the lower right bottom to reshape the web connections 1 Link to comment Share on other sites More sharing options...
RBSdrafter Posted March 25 Author Share Posted March 25 10 hours ago, JiAngelo said: Use the merge and join tools in the lower right bottom to reshape the web connections These tools worked well, but I am still unable to shape the web in order to fit in the corner between the bottom chord and kingpost. Like in the pictures, every time I extend or cut the web to reach these members, it extends past the border of one or the other. Perhaps I don't understand the behavior of roof truss framing members well enough. Link to comment Share on other sites More sharing options...
Solution JiAngelo Posted March 25 Solution Share Posted March 25 Hello, I misspoke. I was using that tool to create piggybacks last week. Here's a link to a video of what you need to do using the clip tool. To snap to the compound shape you just need to select both members then trim the desired member to both in one click. The extend tool works similarly. Chief Architect Premier X16 2025-03-25 11-03-08.mp4 The video was too large to upload. 1 Link to comment Share on other sites More sharing options...
RBSdrafter Posted March 25 Author Share Posted March 25 2 hours ago, JiAngelo said: Here's a link to a video of what you need to do using the clip tool... Thank you! Worked perfectly and has saved me a lot of stress! Link to comment Share on other sites More sharing options...
