Recover a copy door/window casing *from* plan --> to User Catalog
WoodGrain
Go to solution Solved by WoodGrain,
Hi,
I have a plan that I've been working on since Chief x14.
I neglected to backup my user catalog and don't have all the custom moldings that I made for this plan in my x16 User Catalog.
I was able to rescue (Add to Library) custom crown molding & base molding from the Room Specification interface.
Unfortunately I've had no such luck with custom molding from doors and windows...
The interface (that I've been using - double click on the door) doesn't provide an "Add to Library" option.
Is there a different way to rescue these moldings and add them to my x16 User Catalog?
  • Solution
Oh Nevermind... I solved it.
Perhaps this should stay here for others with the same issue.
Using the Full camera view I right clicked on the molding then clicked on "Find original in Library"
then selected the molding - did the search
when it said it wasn't found it gave me an option to add it to the library!
Bingo!
solved.
If you have a symbol, molding, or material that is owned by another object, you can always use the "Add to Library As" tool to extract it and insert it into the library.
