WoodGrain Posted Friday at 12:23 PM Share Posted Friday at 12:23 PM Hi, I have a plan that I've been working on since Chief x14. I neglected to backup my user catalog and don't have all the custom moldings that I made for this plan in my x16 User Catalog. I was able to rescue (Add to Library) custom crown molding & base molding from the Room Specification interface. Unfortunately I've had no such luck with custom molding from doors and windows... The interface (that I've been using - double click on the door) doesn't provide an "Add to Library" option. Is there a different way to rescue these moldings and add them to my x16 User Catalog? Link to comment Share on other sites More sharing options...
Solution WoodGrain Posted Friday at 12:30 PM Author Solution Share Posted Friday at 12:30 PM Oh Nevermind... I solved it. Perhaps this should stay here for others with the same issue. Using the Full camera view I right clicked on the molding then clicked on "Find original in Library" then selected the molding - did the search when it said it wasn't found it gave me an option to add it to the library! Bingo! solved. Link to comment Share on other sites More sharing options...
DBCooper Posted yesterday at 01:31 AM Share Posted yesterday at 01:31 AM If you have a symbol, molding, or material that is owned by another object, you can always use the "Add to Library As" tool to extract it and insert it into the library. Link to comment Share on other sites More sharing options...
