flightcrazed Posted March 12, 2025 Share Posted March 12, 2025 Hello, Anyone with experience putting rigid Polyiso board over sheathing and covering with Metal siding? Curious if this is a best practice (using the polyiso as WRB) or if better to put a barrier between it and the wood sheathing and/or the metal. Thanks! Shawn Link to comment Share on other sites More sharing options...
Gawdzira Posted March 13, 2025 Share Posted March 13, 2025 From the Hammer and Hand best practices https://hammerandhand.com/best-practices/manual/5-envelopes/5-4-exterior-continuous-insulation-ci-at-walls/ Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 18, 2025 Share Posted March 18, 2025 Polyiso has different advice. From the link above Foil-Faced Polyisocyanurate (Polyiso) Exterior surface may be used as a WRB, with manufacturer approval. Install tape at seams per manufacturer specification. 1. Must use J-Roller on tape with good detailing to eliminate ‘Fish-Mouthing.’ 1 Link to comment Share on other sites More sharing options...
