Ange822 Posted March 5, 2025 Share Posted March 5, 2025 Hello! Is there a way to have invisible walls for a deck / not have a drywall finish show on the deck face board? I have been having this issue for a while, to fix it i just manually drag the wall up above the decking and it disappears, but wondered if there was a setting in the wall or deck that I'm missing that could make this easier. I seem to have this issue when drawing invisible walls around a stairway for a deck as well. Thanks in advance! Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted March 5, 2025 Solution Share Posted March 5, 2025 Use a wall type with no Interior or Exterior layers. You should for example have a "Deck Railing/Fence" wall type or maybe a "Frame-3 1/2" wall type (if you're working with a really old template). 1 1 Link to comment Share on other sites More sharing options...
Ange822 Posted March 5, 2025 Author Share Posted March 5, 2025 That worked thank you very much @Alaskan_Son! 1 Link to comment Share on other sites More sharing options...
