TennVol Posted February 10, 2025 Share Posted February 10, 2025 Started using x16. Seems to really lag even drawing basic walls, let alone displaying 3D models. Hope there's some settings I may be able to change rather than upgrading my PC. HP Omen Laptop - 17.3" TouchScreen (1920x1080), 11th Gen Quad-Core i7, 32GB GDDR5, 1TB SSD, NVIDIA GeForce RTX3080. Any suggestions? Thanks Link to comment Share on other sites More sharing options...
ericepv Posted February 10, 2025 Share Posted February 10, 2025 There are quite a few things that can cause your plan to run slow Have you done a disc cleanup recently? Do you have a 3D view open and is it set for PBR? Do you have other apps running that may be using up processing power? I had an issue with a slow file awhile ago that turned out to be caused by a reflective material that somehow got spec'd for the framing. Take a look at this article from the knowledge Base... https://www.chiefarchitect.com/support/article/KB-00521/troubleshooting-slowness-in-chief-architect-plans.html You may need to get tech support involved. Hope this helps - Eric 1 Link to comment Share on other sites More sharing options...
