raltd9245 Posted January 28 Share Posted January 28 Is there a way to have some dimensions in a string show as inches and the rest as feet? Thanks from an old confused man Link to comment Share on other sites More sharing options...
raltd9245 Posted January 28 Author Share Posted January 28 Help with rounding best to use "Grid" or "Distance" HELP??? Link to comment Share on other sites More sharing options...
JKEdmo Posted January 28 Share Posted January 28 40 minutes ago, raltd9245 said: Is there a way to have some dimensions in a string show as inches and the rest as feet? I don't know if you can override the primary format for a single dimension within a dimension string with multiple dimensions. But, you can create a separate dimension, override the primary format and drag it into place. Here's a screenshot. Circled in red is the single dimension whose primary format I overrode to show inches: 1 Link to comment Share on other sites More sharing options...
