raltd9245 Posted January 27, 2025 Share Posted January 27, 2025 How can I go back and remove "tool palate's" when I want to EDIT??? Link to comment Share on other sites More sharing options...
raltd9245 Posted January 27, 2025 Author Share Posted January 27, 2025 i WANT TO RESET TO ORIGINAL SETTINGS Link to comment Share on other sites More sharing options...
mthd97 Posted January 28, 2025 Share Posted January 28, 2025 Hi Ron, have a look at this playlist to find a solution. This might help you reset the toolbar configuration. https://www.chiefarchitect.com/videos/watch/2/using-toolbars.html?playlist=81 Link to comment Share on other sites More sharing options...
Anne_S Posted January 28, 2025 Share Posted January 28, 2025 Hi Ron, Based on your description, it sounds like you are looking for the Edit Toolbar, which lets you edit a selected object or objects and features buttons like Open Object and Copy/Paste. This toolbar is docked to the bottom of the program window by default - but it is empty unless you actually have something in your drawing selected. The Tool Palette, on the other hand, is a side window that's docked to the left side of the program window and it gives you access to the most recently selected tool family: Cabinet Tools, or Door Tools, for example. You can create things using the tools on the Tool Palette - but you can't edit things. I hope that this clarification helps. Link to comment Share on other sites More sharing options...
