Migaloo Posted January 27, 2025 Share Posted January 27, 2025 I am trying to show brick from the top of the floor down to the footing. I got some brick on the porch to show but could not get it to start at the top of floor; I made the wall invisible and extended it 20 inches to get this. Does anyone have other ideas or suggestions to get this done. Chief Talk Foundation issue.zip Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 27, 2025 Share Posted January 27, 2025 13 minutes ago, Migaloo said: I am trying to show brick from the top of the floor down to the footing. change your default foundation wall type to the type of wall you want (Brick over concrete masonry) Link to comment Share on other sites More sharing options...
Migaloo Posted January 27, 2025 Author Share Posted January 27, 2025 I have tried that also. Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 27, 2025 Share Posted January 27, 2025 28 minutes ago, Migaloo said: I have tried that also. and what was the result? what ended up happening that you didnt like? Link to comment Share on other sites More sharing options...
Migaloo Posted January 27, 2025 Author Share Posted January 27, 2025 It appears that the program forces it to be a foundation wall which does not allow you to change the height of the wall. Here is the result. Link to comment Share on other sites More sharing options...
Migaloo Posted January 27, 2025 Author Share Posted January 27, 2025 I applied this to the front porch wall. I do not see a way to change the height or depth of the brick veneer. Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 27, 2025 Share Posted January 27, 2025 34 minutes ago, Migaloo said: I applied this to the front porch wall. I do not see a way to change the height or depth of the brick veneer. heights are determined by rooms, so your foundation room's floor height should be adjusted to adjust the height of the stem wall Link to comment Share on other sites More sharing options...
