Issue in vaulted garage
winterdd
Hey guys, I have a garage with a vaulted ceiling. In that same space I have a safe room and half bath. I have those spaces with 9' ceilings. As you can see below there is no need to run the walls all the way up to the vaulted garage ceiling. I want flat separate ceilings in them. I assume if you guys have an answer to this it will also add back the drywall where I have the question mark. When I delete the upper walls they turn into invisible walls and won't go away completely. This has happened in the past but I just let it fly cause you couldn't tell on the plans but it would be nice to figure out what I am doing wrong.
20 minutes ago, JKEdmo said:
Rob,
I remembered a video about this kind of condition.  See if this helps.
https://www.chiefarchitect.com/videos/watch/64/using-the-shelf-ceiling-room-structure-setting.html?playlist=96
Jim
Dude, this was awesome. It worked and thanks! I will be honest, I have used CA since 2018 and never used the shelf ceiling option.
Me neither.  I just remembered I watched the video when I was evaluating the software a few years ago.  Glad it worked out!
I never knew about the shelf ceiling option, I learned something new, thanks.
I had a similar project over a decade ago but had to find another way around it in X5, the ceiling planes helped me back then.
