winterdd Posted January 23 Share Posted January 23 Hey guys, I have a garage with a vaulted ceiling. In that same space I have a safe room and half bath. I have those spaces with 9' ceilings. As you can see below there is no need to run the walls all the way up to the vaulted garage ceiling. I want flat separate ceilings in them. I assume if you guys have an answer to this it will also add back the drywall where I have the question mark. When I delete the upper walls they turn into invisible walls and won't go away completely. This has happened in the past but I just let it fly cause you couldn't tell on the plans but it would be nice to figure out what I am doing wrong. Link to comment Share on other sites More sharing options...
JKEdmo Posted January 23 Share Posted January 23 27 minutes ago, winterdd said: In that same space I have a safe room and half bath. Rob, I remembered a video about this kind of condition. See if this helps. https://www.chiefarchitect.com/videos/watch/64/using-the-shelf-ceiling-room-structure-setting.html?playlist=96 Jim 2 1 Link to comment Share on other sites More sharing options...
winterdd Posted January 23 Author Share Posted January 23 20 minutes ago, JKEdmo said: Rob, I remembered a video about this kind of condition. See if this helps. https://www.chiefarchitect.com/videos/watch/64/using-the-shelf-ceiling-room-structure-setting.html?playlist=96 Jim Dude, this was awesome. It worked and thanks! I will be honest, I have used CA since 2018 and never used the shelf ceiling option. Link to comment Share on other sites More sharing options...
JKEdmo Posted January 23 Share Posted January 23 24 minutes ago, winterdd said: I have used CA since 2018 and never used the shelf ceiling option. Me neither. I just remembered I watched the video when I was evaluating the software a few years ago. Glad it worked out! Link to comment Share on other sites More sharing options...
mthd97 Posted January 24 Share Posted January 24 I never knew about the shelf ceiling option, I learned something new, thanks. I had a similar project over a decade ago but had to find another way around it in X5, the ceiling planes helped me back then. Link to comment Share on other sites More sharing options...
