usingchief Posted January 10, 2025 Share Posted January 10, 2025 Suddenly - the library materials do not show up as expected. The previewing window is black. ( see pic ) It was all working fine two days ago. And things like this usually happen when there is a critical deadline approaching. SO,.... What do I need to do to fix this? TYIA Macbook Pro / Sequoia 15.1.1 CA version X16 Link to comment Share on other sites More sharing options...
DBCooper Posted January 10, 2025 Share Posted January 10, 2025 Try playing around with those tools that control the preview. You can switch the rendering style as well as the preview object. It looks like you are currently using a plane and you could try switching to a cube. Also, could try switching between standard, PBR, and vector. Might be a video card or driver issue too. I assume you rebooted but you should if you haven't tried that yet. Not sure about how mac handles drivers. If that doesn't help, you should probably contact tech support. Link to comment Share on other sites More sharing options...
