winterdd Posted Friday at 05:42 PM Share Posted Friday at 05:42 PM Guys, what is the easiest way to add a wall above this entertainment center in a vaulted area and close off that space? I am not familiar with a tool to do this that I bet exists in CA. Link to comment Share on other sites More sharing options...
DBCooper Posted Friday at 06:15 PM Share Posted Friday at 06:15 PM You could just fill it in using a poly solid. You could also draw a wall there and then make a pass thru for the cabinet to fit in. 1 Link to comment Share on other sites More sharing options...
winterdd Posted Friday at 06:18 PM Author Share Posted Friday at 06:18 PM 1 minute ago, DBCooper said: You could just fill it in using a poly solid. You could also draw a wall there and then make a pass thru for the cabinet to fit in. I was gonna do a polyline solid but like your idea of the pass thru too. Would the soffit tool be something good for this too? Link to comment Share on other sites More sharing options...
DBCooper Posted Friday at 06:24 PM Share Posted Friday at 06:24 PM I don't think a soffit can follow the ceiling and also be flat on the bottom. Link to comment Share on other sites More sharing options...
Kreg_Joue Posted 22 hours ago Share Posted 22 hours ago I typically add a door opening and turn off the casing and jamb. Then the attic walls build above. 1 Link to comment Share on other sites More sharing options...
winterdd Posted 3 hours ago Author Share Posted 3 hours ago 19 hours ago, Kreg_Joue said: I typically add a door opening and turn off the casing and jamb. Then the attic walls build above. Good solution as well. Link to comment Share on other sites More sharing options...
