winterdd Posted January 10, 2025 Share Posted January 10, 2025 Guys, what is the easiest way to add a wall above this entertainment center in a vaulted area and close off that space? I am not familiar with a tool to do this that I bet exists in CA. Link to comment Share on other sites More sharing options...
DBCooper Posted January 10, 2025 Share Posted January 10, 2025 You could just fill it in using a poly solid. You could also draw a wall there and then make a doorway or a pass thru for the cabinet to fit in. 1 Link to comment Share on other sites More sharing options...
winterdd Posted January 10, 2025 Author Share Posted January 10, 2025 1 minute ago, DBCooper said: You could just fill it in using a poly solid. You could also draw a wall there and then make a pass thru for the cabinet to fit in. I was gonna do a polyline solid but like your idea of the pass thru too. Would the soffit tool be something good for this too? Link to comment Share on other sites More sharing options...
DBCooper Posted January 10, 2025 Share Posted January 10, 2025 I don't think a soffit can follow the ceiling and also be flat on the bottom. Link to comment Share on other sites More sharing options...
winterdd Posted January 11, 2025 Author Share Posted January 11, 2025 19 hours ago, Kreg_Joue said: I typically add a door opening and turn off the casing and jamb. Then the attic walls build above. Good solution as well. 1 Link to comment Share on other sites More sharing options...
